Features
Total posts in this thread: 8
Previous Thread This topic has been viewed 1891 times and has 7 replies Next Thread
platax
applause calculating outside surface of all walls
Hello,
I want to insulate my house from outside.
I need to calculate all outside wall surfaces, and all doors and windows perimeter.
Since I already made a whole plan using SH3D, is there an easy way to do this ?
Thanks
[May 18, 2017 9:36:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: calculating outside surface of all walls
Hello,
Thanks
No ! sad
Just manually put a fictive room in the outside walls for the first part and multiply by the height.
For the second part (doors and Windows) take a calculator and substract the result from the first part. biggrin
talk to the hand
only 5.7 and nothing else - W10 64b
[May 19, 2017 5:51:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Actually, there is an easy way: Plugin #5 ComputeWallsSurface will calculate for you (albeit with some caveats mentioned on plugin download page and discussions such as thread 7516: Calculating the surface of the wall).
If you take into account that it measures the inside of the wall, it should do pretty much what you want if you install the plugin, restart sh3d, select the outer walls and run the plugin from the tools menu.
Good luck with your insulation project.
[May 19, 2017 8:41:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Great, I didn't know this plugin ! applause
But there is a problem, this plugin calculates surface from the middle of the walls. sad
Platax asks us an outside walls surface... it's not the same ! tongue
So, the lonely solution is manual calculations... crying
See below the demo (height of the walls = 1.0 m) :
See lines and distance with the calulated surface...
[Edit 2 times, last edit by bdfd at May 19, 2017 10:44:24 AM]
[May 19, 2017 10:08:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yes, if you read my post I mentioned that. platax wants to insulate from the outside. I do not know about you, but the three times I have re-insulated a house, I put the insulation inside the wall. In my experience that works quite well. Perfect accuracy is an illusion anyway as some surplus insulation (waste) must be calculated.
platax - you probably know this - but there are insulation calculators online that will help you estimate different insulation types: acoustic, moisture, wind, thermal etc.
[May 19, 2017 11:19:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
If you want know distance of outside walls, it's false. sad
If you want know distance of inside walls, it's False too (in a house already made) !!! crying
Conclusion : Don't use this plugin. sick
[Edit 1 times, last edit by bdfd at May 19, 2017 2:25:02 PM]
[May 19, 2017 2:00:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
And if you want to know the inside of the wall, for, say, insulation?
While I do not share bdfd's concerns about the plugin using measurements from the centre of the wall, that is easy enough to adjust for.
Nevertheless, put the plugin trough a little test. And while it behaved well on one or two sloping walls with a few cut-outs, it seems to have problems with many walls/openings - at least, I could not get the results I expected (but that may be me). So, I might still use the plugin, but I would double check the result.
[May 19, 2017 5:00:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
In a house already made, simply 'very very very' difficult ! sick
A 'not easy' solution :
1. Insert a fictious wall with thickness equal to 0,001 m
2. Place it with the dimensions of the real outside wall
3. Select it and use the plugin.
Repeat 1-2-3 for each wall. biggrin
Good luck... wink
[Edit 1 times, last edit by bdfd at May 19, 2017 5:59:01 PM]
[May 19, 2017 5:39:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
