Bad render quality - can't find the reason
Hi!
I'm using SH3D for the first time and I like it very much. But always when I try to render an image, regardless of the quality settings or image size, quality is very bad (noise, not sharp). I'm sure, I'm doing something wrong, but I can't find out what actually...
I'm using the latest version, 5.4 portable 64bit on Windows 7 pro 64bit. My graphics card is a Intel HD 4600 builtin Lenovo T540 laptop.
Here are some examples, where you can see, that it is absolutely independent of image size or viewport or what not...
Re: Bad render quality - can't find the reason
Hi! I'm using SH3D for the first time and I like it very much. But always when I try to render an image, regardless of the quality settings or image size, quality is very bad (noise, not sharp). I'm sure, I'm doing something wrong, but I can't find out what actually... I'm using the latest version, 5.4 portable 64bit on Windows 7 pro 64bit. My graphics card is a Intel HD 4600 builtin Lenovo T540 laptop. Here are some examples, where you can see, that it is absolutely independent of image size or viewport or what not... I hope, someone can help me... Regards, Holger
Did you see advanced parameters (for you : Tiefenscharfe) ?
You can see more examples in gallery section...
Yes, thanks! I mostly solved the problem by using "Standard", not "Tiefenschärfe" and settings a really high resolution. But will go through the gallery, too!
