Malta
Creating a garage ramp
First of all well done for this software! I'm still new using it, but have managed to figure out a number of features with the help of the tutorials & forum.
Re: Creating a garage ramp
Place a triangular shape on the basement level (outside) and adjust height to ground level. It will cut a hole in the ground. There are several forum posts (e.g.6297 and 7134). Cannot find the most detailed one off hand, though. ok
Australia
I made this model with transition slopes, transparent roof, and clearance sign. It is too long for most domestic uses but resizing may give you something useful.
Malta
Update: I managed to do the ramp using the triangular shape you sent me. Thanks!! The ramp model looked awesome, but couldn't adapt it for my needs.
I also managed to create stairs in Sketchup and import them into SweetHome3D. Still trying to figure out how to create it in such a way that when you go to Modify furniture / Materials, there are separate materials for each part of the stairs (sides, risers etc)
It is possible to rename materials in Sketchup (e.g. from 0003_DeepPink to Railing), and a model exported to .dae and imported in SH3D will keep the same material names.
Avoid using two sided export (in Export 3D options). And you may have to use orient or reverse faces in Sketchup to get the surfaces right.
