Hong Kong, SAR
How can I create windows the way I want it?
I just finished drawing the wall of my apartment and wish to add windows to the wall but encountered two problems:
1. When I have the windows opening to the side that I want, the hedges are all on the exterior of the wall. How can I move the hedges to the interior of the wall?
2. I want to create 3 windows side-by-side to each other. I used a double-window + a single-window. But then, a partition appears between the joint of the two windows. How can I remove the partition or how can I create a normal tri-window?
Re: How can I create windows the way I want it?
For the first, clic on the window and move lightly to down or up and the window will be change its opening direction (with magnetism option = ON).
for second point, remove 'magnetism' option and after a zoom, move the second window againts the first.
[Edit 1 times,
last edit by bdfd at Jun 5, 2017, 6:38:43 AM]
Best way to make bespoke windows - draw the window frame(s) using thin walls - scale height of walls to thickness of window frame - insert glass boxes as windows - export, import and rotate to vertical
