Previous Thread This topic has been viewed 4112 times and has 2 replies Next Thread
enkonyito
Add a new home property to a change listener
The setProperty method allow to set a new property associated with a home.
But can this property be taken into account by the addPropertyChangeListener method without returning an IllegalArgumentException if you use valueOf (String name)?
With this code:
this.home.addPropertyChangeListener(Home.Property.valueOf(ENHANCED_EXTERNAL_BRIGHTNESS),
new PropertyChangeListener() {
public void propertyChange(PropertyChangeEvent ev) {
isEnhancedExternalBrightness = Boolean.parseBoolean(home.getProperty(ENHANCED_EXTERNAL_BRIGHTNESS));
externalBrightnessEnabledCheckBox.setSelected(isEnhancedExternalBrightness);
I have this error:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: No enum constant com.eteks.sweethome3d.model.Home.Property.enhancedExternalBrightness
EnkoNyito
[Jun 7, 2017, 2:15:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Add a new home property to a change listener
The method valueOf of an enum takes into account only values of the enum that exist.
The main problem comes from the fact that enums are final, and using enums for these properties is actually a wrong idea I had sad
[Jun 7, 2017, 10:51:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
I wanted to bind the enhance external brightness option of the photo panel to the video panel.
The alternative would be an implicit selection from the photo panel only.
I do not know if other developers needed to add a new home property to existing ones but if there is a solution for it to be possible without too much changing the source code, why not?
EnkoNyito
[Jun 7, 2017, 8:29:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
