Features
Previous Thread This topic has been viewed 1202 times and has 2 replies Next Thread
hoangtrunglien
usa
How to edit a room
I have created a room and the size of it is now shown. How can I make the room larger or add another room to it? I do not know the keys I need. Dragging the edges does not leed to what I want.
Thanks for your help.
[Jun 25, 2017 9:13:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: How to edit a room
Try to cancel the 'magnetism' option to update the room,
or
Add new walls for new room...
only 5.7 and nothing else - W10 64b
[Jun 26, 2017 6:00:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I guess you moved the walls, expecting the room points would follow but this is not how Sweet Home 3D works. Select the room surface and move the points to the new wall corners, and you'll see that magnetism will help you place them easily on the corners. You may also delete the room surface and create it again with the room creation tool.
[Jun 26, 2017 9:20:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
