CN
Sweet Home 3D online adding menu bar
Hi, Thanks for help last time. I can now successfully embed sweet home 3d online into my system. But still have several questions. Would u kindly help?
1. From the user guide, I know online version have no menu bar. But if there way adding for online version? For example, I need to rotate my mansion and I know there having a [AdvancedEditing.sh3p] plugin to solve it. But it is added to the menu bar. So online version cannot use it?
2. Moreover, is there guide for adding plugin on online version? As we may need to add the existing plugins and develop a plugin for specific requirement.
Would you please kindly help for above 2 questions? Thanks very much.
Re: Sweet Home 3D online adding menu bar
Sorry, don't expect help on the applet version, because applets require the Java plugin, a dying solution since it's still supported only under IE and Safari.
Not at the moment for Sweet Home 3D. But probably in the future once the new editor programmed in JavaScript will be ready. Read this article for more information.
yesong, the current online version is still based on Java applets, so you shouldn't invest time on a solution that may be deprecated in the future. The JavaScript version evolved this year but it's still just a 3D viewer and is not able to edit Sweet Home 3D files.
