Total posts in this thread: 98
Posts: 98   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 208637 times and has 97 replies Next Thread
Re: Sweet Home 3D 5.5
The version 5.5 beta 10 (Java Web Start, Windows installer and Linux 64 installer) comes with an update of Hungarian translation and a new look for the Furniture modification dialog box with different labels for the rotation around the horizontal axes.
Hope you'll find it clearer smile
I propose also a second installer for Windows with the version 5.5 beta 11, to get your feedback about how Sweet Home 3D works with the latest Java Runtime Environment 1.8.0_144, one year later I decided to stuck on JRE 1.8.0_51 to fix the crash problems encountered by some of you (the installer of Sweet Home 3D version 5.5 beta 10 still comes JRE 1.8.0_51). To check if it works better, I hope some of you will have the patience to test whether Sweet Home 3D 5.2 still crashes, then try the new version 5.5 beta 11.
Thanks for your tests smile
If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
[Edit 2 times, last edit by Puybaret at Aug 4, 2017, 7:17:04 PM]
[Aug 4, 2017, 4:06:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Linux_64_installer links downloads a file called SweetHome3D-5.5.beta11-jre1.8.0_144-windows.exe.
Is that correct?
[Aug 4, 2017, 4:42:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry Hans, I fixed the link. Thanks for reporting the issue smile
[Aug 4, 2017, 5:28:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
...If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
Not chance !
It's now the second link for linux which is bad... biggrin
[Aug 4, 2017, 6:38:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fixed. Thank you. Bad luck wink
[Aug 4, 2017, 7:18:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Guess 'nothing to report' can also be a report smile Worked my way through the features and did some random editing, and Java Web Start seems to work beautifully under Win81. Thanks for the new features. ok
[Aug 7, 2017, 1:56:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Just a remark : Today, I use sh3d 5.5 beta11 in exe mode with success.
I won in using jlnp method with a good '.bat' file. biggrin
but i saw that the launched version was beta12 !
Is it the good ?
[Aug 8, 2017, 9:48:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Is it possible for the camera to tilt along the Y axis like furniture?
EnkoNyito
[Aug 11, 2017, 8:14:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bdfd, I don't post a message at each update, moreover when it's about very small changes, but you're right, the current beta version is 12.
Enkonyito, I wonder what your request could be useful for.
[Aug 11, 2017, 10:00:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Emmanuel, this "roll" option may not be very useful applied to the virtual visitor but in the case of a video rendering this would be an additional basic camera movement.
EnkoNyito
[Aug 15, 2017, 2:37:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
