Japan
Re: Sweet Home 3D 5.5
This isn't really related to the new version, but I thought I'd mention it here anyway. I have a MacBook Pro with the LG 5k monitor. When running SH3D on that monitor it is quite slow. It seems that's because of the very high resolution. Interestingly it's slow not just operations that involve the main layout screen, just bringing up normal dialog windows is slow to the point that I can see the dialog components being drawn in the window. If I reduce the size of the window, or adjust the resolution settings, then it does get better, but obviously I'd like to use the full resolution if possible.
Again, this isn't new to the new version.
On a side note, is there a jar-only build of the new version so I can run it with Java 8 on MacOS?
Sweet Home 3D 5.5 was released today (including a Jar executable version, but without the portable version yet). Thanks to you all for your feedback and help!
Japan
The builtin display is 2880x1800 and the external monitor is 5120x2880. I usually show the floor plan on the external monitor and the 3D view on the builtin.
There seems to be a problem with creating pictures and videos at the two lowest qualities. I have tried with OSX Sierra 10.12.6, and with Yosemite 10.10.5.
