Export OBJ and import to Sketchfab is shown without textures and colors
When I export to OBJ a simple 3D model and load it into sketchfab, it'll show all of the textures and colors. When I export a bit more complex 3D model with different furnitures etc it'll show in sketchfab only geometries without textures and colors. Is there a tip to handle more complex models with textures?
Re: Export OBJ and import to Sketchfab is shown without textures and colors
Did you try to reimport the more complex OBJ model in Sweet Home 3D itself with the furniture import wizard or in Blender? By the way, if you want to view a Sweet Home 3D file on the web, you could give a chance to HTML5 export homes manager.
United Kingdom
I have the same issue. Tried saving as furniture object, importing that furniture item into a new file, thinking it might undergo some sort of compression and then tried exporting that to OBJ. Still get same non-textured, white, output.
