Total posts in this thread: 4
Previous Thread This topic has been viewed 1327 times and has 3 replies Next Thread
quanghieuci
tphcm
2 Question (Where model 3D "Open Door" and Flip A House )
hi
In Sweet Home 3D examples, I can see that the doors are always represented OPEN but in my archive 3D models there is no "OPEN DOOR". May I know where can I find it?
and second question :
In some areas of NYC, there are houses that are mirrored copies of the one next to it. They share a common wall area (sometimes its 2 walls side by side as 1) between the two, and along that wall, one house is a mirror copy of the one next to it. If the original has a set of stairs to the left, the mirrored house would have a set of stairs to the right, and so on.
Any way to grab a whole house or floors of a house and mirror flip it? I tried grouping but that only works on furniture, windows and doors, not walls or rooms.
Thanks for the help!
[Jul 27, 2017, 3:19:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2 Question (Where model 3D "Open Door" and Flip A House )
hi
1. And yes, there is ONE example in Doors & Windows section called Open door... cool
2. You must install a plug-in called advancedediting : see plugin section
Two simple searches, you aren't curious. laughing
[Jul 27, 2017, 6:16:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bdfd, your answer is not very sweet!
Quanghieuci, are you sure you downloaded all the Sweet Home 3D librairies? There are 4 models of open doors in the free models.
For a mirrored copy, you can also export the whole house then reimport it in the direction you want.
[Jul 27, 2017, 7:07:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
VeroniQ, exporting then reimporting a whole house won't let you change it afterwards. If it will be possible to arrange furniture in it, it won't be easy since the imported house will behave like a big piece of furniture!
[Jul 27, 2017, 7:44:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
