Re: Menu all crammed together
You're probably using a HiDPI screen in which case you should look at the FAQTexts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that?
I would double check the suggestion of the FAS. And if it still doesn't work, it will be impossible to help you without at least an image...
