Features
Total posts in this thread: 2
Previous Thread This topic has been viewed 2121 times and has 1 reply Next Thread
WenFai
CN
confused how to decide outside walls
Another question :
we want to select the outside walls of a house.
As we want to build a community with several top buildings, we draw each building with just one level,then the plugin extend it to a building. we don't need the walls inside the building, we just use the outside walls to build it.It could help to reduce the stress for the program to show the home view.
But the walls is not just a line, it could be a circular arc with a property named arcExtent.
Is there any method can help with it in API? or any other ideas?
Thanks
[Aug 1, 2017 11:07:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: how to decide outside walls
There's no method in the program to detect outside walls.
Maybe you could reuse wallsAreaCache handled in PlanController to get its exterior path(s) using getAreaPoints in Object3DBranch. The exterior walls should be the ones that intersect with this exterior path, but that won't work if an interior wall touches the border of an exterior wall.
[Aug 1, 2017 12:52:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
