Canada
Need Help importing/viewing Textures Libraries
When using the application, I am unable to see/find the textures libraries I downloaded and imported. I choose textures for a room to put in a hardwood floor and it's still the same deault ones that were there with the install. No new ones are appearing in the list box. I select import and that doesn't lead me to any textures files. Am stuck here. Any help would be much appreciated. Otherwise just loving this saweet 3D application.
Re: Need Help importing/viewing Textures Libraries
Depending on the way you imported textures, you can find them using one of the two following ways: - individually imported images as textures are written with an italic font in the textures list of the dialog box that lets you choose a texture - imported textures libraries are listed in Textures libraries section of the Libraries in use pane. This pane is displayed by clicking on the Libraries... button shown at the bottom of Sweet Home 3D About dialog box.
