Previous Thread This topic has been viewed 5494 times and has 2 replies Next Thread
enkonyito
Method not accessible from a plug-in
By checking the compatibility of the PhotoVideoRendering-1.3 plug-in with SweetHome3D-5.5, I get an error after integrating the PhotoRenderer file update.
Error message: "The method getPieceOfFurnitureNormalizedModelTransformation (HomePieceOfFurniture, Node) from the type ModelManager is not visible".
PVR-1.3
SH3D-5.5
Is there a way to circumvent this restriction?
EnkoNyito
[Sep 8, 2017, 2:28:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Method not accessible from a plug-in
I guessed you would need getPieceOfFurnitureNormalizedModelTransformation, made it public during half an hour, and finally changed my mind because I didn't want that a method with such parameters be part of the API.
Just copy / paste it in your own code.
[Sep 8, 2017, 2:50:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
At first the solution did not work but with perseverance the problem was solved.
Thank you!
EnkoNyito
[Sep 9, 2017, 1:24:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
