Total posts in this thread: 2
Previous Thread This topic has been viewed 4626 times and has 1 reply Next Thread
tomhf
Existing and Proposed Condistions
I am doing a plan for remodeling a second floor and adding a bathroom. Is there a way to distinguish between existing and proposed features on the plan to show what is being removed and what is new on a single plan sheet. Typically the existing conditions would be shown as lighter and walls to be removed can be identified. Not sure how to do that with this program.
[Sep 19, 2017, 2:29:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Existing and Proposed Condistions
I would suggest to use three levels at the same elevation :
- one where you draw everything in common (walls, rooms and furniture that won't change)
- one where you draw things you want to remove or move
- a last level where you draw new things.
Then you can make viewable either two last levels to view the differences.
[Sep 20, 2017, 6:05:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
