Existing and Proposed Condistions
I am doing a plan for remodeling a second floor and adding a bathroom. Is there a way to distinguish between existing and proposed features on the plan to show what is being removed and what is new on a single plan sheet. Typically the existing conditions would be shown as lighter and walls to be removed can be identified. Not sure how to do that with this program.
Re: Existing and Proposed Condistions
I would suggest to use three levels at the same elevation : - one where you draw everything in common (walls, rooms and furniture that won't change) - one where you draw things you want to remove or move - a last level where you draw new things. Then you can make viewable either two last levels to view the differences.
