Re: Cubic houses - part 2
Hi bdfd Not sure removing the door to the laundry is good, no access now from the kitchen and to take the washing outside to hang it has to be carried through the tech room, may need a bit of revision m8. Also suggest the cooker move to the right of the fridge to improve the movement triangle. Kitchen does have a nice airy feel to it with the large door/window.
Hi Mike,
Thank you mate for your return. But don't panic Mike, the door is not far.
At this moment, I didn't always validate the opening direction of the new door.
In this part of plan you can see the kitchen and watch the updates : Red cross : the old location of the door. Green check : the new Green lines do a losange surface with four points between : 1. the sink, 2. the fridge, 3. the cooking plate and 4. the double oven. Another updates are possible (as moving to left the fridge and double oven to optimize the way like a square). => Perhaps a nextly version.
LOL, I think that your own cabinets (very well done ) are perhaps too separated by a long distance.
Kitchen does have a nice airy feel to it with the large door/window. Mike
TY, this large window gives on the terrace equipped by a pergola.
Looks like that door position works well, if it were mirrored, green lines as a square would work smoother than a rhombus. My "kitchen" is a collection of cabinets arranged very scientifically by handle hieght and angle and a way to get them all in one image.
View of the living room.
FYI : the restriction on the size of windows is only applicated for large windows with openings. Each standard moving part cannot be more 2 meters of width.
