Support for high sierra (10.13)
This topic has been viewed 13057 times and has 2 replies
Thread status: Active
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
eniavlys
Post by eniavlys »
I'm balancing pros and cons in upgrading my mac to high sierra (10.13) right now. In Sweet home 3D's home page, it's explicitly said that support is provided for mac os up to 10.12. However, reading through the forum, I had the feeling that v5.5 actually does run on mac os 10.13.
So: do I have any chance of running a -kind of, even not 100%- stable version of sweet home 3D on mac os 10.13? Is there a specific beta version of sweet home 3D to use, or should v5.5 do a good enough job there for the moment? Or did I completely misunderstood things and there's for the moment no chance at all to get sweet home 3D to run on mac os 10.13? If so, do you have any idea on when sweet home 3D will run on mac os 10.13?
Thanks!!
User avatar
Country: Paris, France
Contact:
Re: Support for high sierra (10.13)
Post by Puybaret »
Sweet Home 3D works under High Sierra. As explained here, the only remaining issue prevents to attach the menu bar of the application at the top of the screen on non English systems. So while Apple or Oracle is fixing this regression that happens on many Java applications, I programmed a workaround that displays the menu bar at the top of each Sweet Home 3D window. It's up to you to decide if you can live with that detail or not.
eniavlys
Post by eniavlys »
Dear Emmanuel,
Great! Thanks! Indeed I *can* live with this minor limitation, so I'll upgrade.
Thanks for your work!
Who is online
