Features
Total posts in this thread: 2
Previous Thread This topic has been viewed 739 times and has 1 reply Next Thread
ChrisPapp
orientation of walls
Dears,
we downloaded Sweet Home 3D for a project a few days ago. It's a great tool and quite easy and focussed for our demand.
Only 1 thing, where I do not find a solution: Is it possibe to fix a wall with a certain thickness at and then set thickness?
Let's say a 3m long vertical wall starts at (0,0) with a thickness of 30, then currently the left ends at (-15,300) and the right side at (15,300). The issue with this in a complex drawing with different wall sizes the measurements are quite complicated if you mix draw from a drawing and measure. You allways need to consider wall thickness in the drawings.
Is there a possibility to fix the wall orientation not to the middle of the wall but to an edge?
Thx
Chris
[Oct 14, 2017 8:43:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: orientation of walls
No, walls are always drawn with the coordinates defining the middle of start and end point
[Oct 14, 2017 6:27:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
