Total posts in this thread: 4
Previous Thread This topic has been viewed 4013 times and has 3 replies Next Thread
Dubina
I once used AutoCAD and now I wonder...
...if my new free SH3D is automatically set to snap to grid points. If so, I do not understand how that works. Also, I would like"
1. to rotate a plan wall around a point.
2. to be able to "mirror" two sections of a plan wall
3. specify the angle between two connected plan walls when the angle is not 90 degrees.
I don't knowif any of that is possible w/ SH3D but I think it must be because some of the rendered projects I see are so elaborate.
I would greatly appreciate any help / advice.
Dubina
[Oct 14, 2017, 6:10:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Dubina
Re: I once used AutoCAD and now I wonder...
Let me elaborate a problem that I wrote here earlier.
My home is not rectangular: the exterior walls are shaped like the side profile of a modern round brilliant diamond cut...in other words, a pentagon Those exterior walls are not rectangular; they have two interior 90 degree angles and three interior non-90 degree angles, so it's difficult (and maybe impossible) to draw the exterior and interior walls because the wall lines that I draw seem to snap to the SH3D plan grid. I can draw the two exterior side walls of the house that meet at right angles, but I haven't been able to join them together to form the exterior pentagon. What to do?
[Oct 15, 2017, 12:25:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I do not see where the problem is for any form of houses.
Use SH3D v 5.5.2 or more and the option "joined the walls"...
wink
[Oct 15, 2017, 1:20:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Dubina, there's no snap to grid in Sweet Home 3D, but there's some magnetism to help you draw parallel walls, place windows on walls, place objets along walls, beside other objects... Just disable magnetism in preferences if you don't need it (read also help).
[Oct 15, 2017, 6:01:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
