Total posts in this thread: 8
Previous Thread This topic has been viewed 6831 times and has 7 replies Next Thread
simona70
Can't start sweethome3d on Linux
Intel z270, i7-7700K, Linux 4.13 (4.13.8-1-zen), arch linux distro, Sapphire NITRO+ RADEON RX 580 Special Edition 8G GDDR5, amdgpu driver, 16gb ddr4, de KDE. system full updated, Linux-zen kernel.
Extended renderer info (GLX_MESA_query_renderer):
Vendor: X.Org (0x1002)
Device: Radeon RX 580 Series (AMD POLARIS10 / DRM 3.18.0 / 4.13.8-1-zen, LLVM 5.0.0) (0x67df)
Version: 17.2.2
Accelerated: yes
Video memory: 8143MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
OpenGL vendor string: X.Org
OpenGL renderer string: Radeon RX 580 Series (AMD POLARIS10 / DRM 3.18.0 / 4.13.8-1-zen, LLVM 5.0.0)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 17.2.2
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
I get the splash screen and then nothing happens.
Running from a console, I can see the error messages/call stack.
I especially notice:
Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped
Full call stack from error:
at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2071)
at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1924)
at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875)
at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1843)
at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230)
at java.security.AccessController.doPrivileged(Native Method)
at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216)
at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1021)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050)
at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803)
at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:317)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:207)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
[Oct 22, 2017, 9:45:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can't start sweethome3d on Linux
The Linux version comes with a startup-script called Java-1.5 or something similar. Use that script to start SH3D.
[Oct 22, 2017, 11:35:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
simona70
Sorry.... in my aur arch linux sweethome3d package I don't find any java script (there is a .desktop ...). Anyone can publish this script content?
[Oct 22, 2017, 3:02:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
#!/bin/sh
# Retrieve Sweet Home 3D directory
PROGRAM=`readlink "$0"`
if [ "$PROGRAM" = "" ]; then
PROGRAM=$0
fi
PROGRAM_DIR=`dirname "$PROGRAM"`
# Run Sweet Home 3D
exec "$PROGRAM_DIR"/jre8/bin/java -Xmx1024m -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Examples.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1b.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/j3dcore.jar:"$PROGRAM_DIR"/lib/j3dutils.jar:"$PROGRAM_DIR"/lib/vecmath.jar:"$PROGRAM_DIR"/jre8/lib/javaws.jar -Djava.library.path="$PROGRAM_DIR"/lib -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open "$1"
[Oct 22, 2017, 4:34:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
simona70
smile [solved] Re: Can't start sweethome3d on Linux
Solved.Thanks.
It's Archlinux packet in [Community] that is buggy. Original java packet in SweetHome3D site is ok.
[Oct 22, 2017, 6:16:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
richardlyons
I was thrilled to find this script, as I had the same problem on Arch Linux. I had to change "readlink" to "realpath" but SH3D then loaded. Very disappointed that it is not in fact doing any 3D. The bottom right panel remains blank and the plan shows a jumble of white rectangles where furniture and other items should be. Such a pity not to be able to run this application.
[Jan 24, 2018, 10:28:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
richardlyons
In the start script above, it probably depends on your shell, but may be necessary to replace (in line 4) the deprecated "readlink" with "realpath" to get the intended result.
[Jan 25, 2018, 1:30:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
richardlyons
Re: [solved] Re: Can't start sweethome3d on Linux
Further explanation of the problem using SH3D on Arch Linux.
Installation of the package available for the distro results in only the splash screen. Using the start script is difficult because the libraries listed are located in different directories. It may be possible to edit the script. I have not tried as I am unsure how to select compatible versions.
Installing from the SweetHome3D site, it is easy to edit the script to start the program, but the 3D rendering fails. The following errors are generated (it looks as though the first few lines are critical):
Java 3D: implicit antialiasing enabled
amdgpu_parse_asic_ids: Cannot parse ASIC IDs: Ressource temporairement non disponible
Exception in thread "AWT-EventQueue-0" javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D
at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.access$200(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:86)
at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:193)
at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:180)
at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179)
at java.awt.Component.processComponentEvent(Component.java:6365)
at java.awt.Component.processEvent(Component.java:6313)
at java.awt.Container.processEvent(Container.java:2237)
at java.awt.Window.processEvent(Window.java:2025)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2295)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82
[Jan 26, 2018, 9:46:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
