Features
Previous Thread This topic has been viewed 709 times and has 9 replies Next Thread
Marbel
Italy
File boot and 3D problem
Hi, when I try to boot a file it is necessary a lot of minutes to complete the boot. There is an icon like a clock over every object. At boot terminated the render 3D do not work properly, it go at step (very slow). I update at 5.6 version and also Java is updated. Since some week ago all was OK. My notebook is HP Pavilion I5 with 8 Gb ram.
Thanks for help
Marco
[Nov 11, 2017 5:28:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: File boot and 3D problem
OS ?
Size of your file ?
zipped or not ?
Try to delete heavy objects...
only 5.7 and nothing else - W10 64b
[Nov 12, 2017 11:11:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Marbel
Italy
Windows 10 home edition.
File size 100 MB
"zipped or not" ? what means
Where I can see the size of objects?
Thanks
[Nov 12, 2017 12:49:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
OK.
File size 100 MB
2 ways to save a file :
"save as" and "save and compress"
What did you do ?
Right click on the list in lower left frame and choose "display column" and "size model"...
[Nov 12, 2017 1:19:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Marbel
Italy
I save only "save as".
What is (apart save MB) the difference if you open an use a compressed o not compressed file?
And, what about my problem ? Do you know a possible solution
Thanks
[Nov 12, 2017 3:16:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
I think that W10 home, 8 Go and 100 MB are not enough for sh3d and java... crying
[Nov 12, 2017 5:24:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Marbel, you should try to increase the max memory used by the program, unless you use the 32 bit version of Sweet Home 3D (see in the About dialog of Sweet Home 3D).
[Nov 12, 2017 11:09:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
Marbel
Italy
I am using: Sweet Home 3D ®
Versione 5.6 Java Web Start
Versione Java 1.8.0_151 / 32 bit / 0,6 GB max
Versione Java 3D 1.6.0.
Is a 64 bit version for windows??
If yes, how much can I increase the max memory for the program (I have 6 Gb ram). Thanks
[Nov 13, 2017 12:52:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
If your system is 64 bit, try the installer version which will install Sweet Home 3D 64 bit.
[Nov 13, 2017 2:44:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
Marbel
Italy
OK, thanks
[Nov 13, 2017 11:19:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
