Total posts in this thread: 9
Previous Thread This topic has been viewed 8964 times and has 8 replies Next Thread
cool Sliding door glazed
Here are two new models of sliding doors glazed, one opened and the another closed.
Closed
Opened
Download and unzipp them before to import.
IMPORTANT !
do not forget :
to add an standard embrasure in black color,
for import, click on the option 'door and window',
to remove the magnetism to put the sliding door glazed,
Put the sliding door glazed near the wall, not in.
# This file is distributed under the CC-BY Creative Commons Attribution 3.0 Unported license
# available at http://creativecommons.org/licenses/by/3.0/ or under the terms of the GNU General Public License
# as published by the Free Software Foundation and available at http://www.gnu.org/copyleft/gpl.txt
Verriere fermee = closed
Verriere ouverte = opened
Regards.
Attachment Verriere fermee.zip (132145 bytes) (Download count: 2962)
Attachment Verriere ouverte.zip (142885 bytes) (Download count: 2733)
[Edit 4 times, last edit by bdfd at Dec 13, 2017, 7:20:54 PM]
[Dec 12, 2017, 7:13:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: Sliding door glazed
Well done, Bdfd, and so fashionable!
[Dec 12, 2017, 10:13:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
..add an standard embrasure in black color, for import, click on the option 'door and window', to remove the magnetism to put the sliding door glazed, Put the sliding door glazed near the wall, not in.
Or add library properties (see thread 2006 for the whole shebang), something like this guestimate:
doorOrWindow#1=true
doorOrWindowCutOutShape#1=M 0.029,0.04 h0.46 v.962 h-0.46 z
doorOrWindowWallThickness#1=15
doorOrWindowWallDistance#1=-6.2
Or even edit the <doorOrWindow .../> properties in Home.xml replacing:
wallCutOutOnBothSides='true' boundToWall='false'
by something like:
wallThickness='0.903616' wallDistance='-0.373494' cutOutShape='M 0.029,0.04 h0.46 v.962 h-0.46 z' wallCutOutOnBothSides='true'
Backup first, though, easy to make a mess smile The cutout will be the same in both cases, but in Home.xml all values are relative to model size, also wall alignment. As model is 16.6 deep wallThickness = 0.903616 (15/16.6) and wall Distance -0.373494 (-6.2/16.6).
PS. In light of the hols approaching, all concerned with dietary requirements of models, there is information in SF 3D models 261. Combined with a bit of editor magic, it is quite astonishing how small it is possible to make a model.
[Dec 12, 2017, 3:10:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks to Lady Vero & okh.
It's an another way to give 3D models with automatic import. wink
[Dec 12, 2017, 5:06:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry, do not get it. Could you rephrase, please? ok
[Dec 12, 2017, 6:05:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A sh3f file can be importing into sh3d automatically.
[Dec 13, 2017, 6:48:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
..sh3f file...
Ah yes. I might have mentioned that library is about .sh3f files; and that while the cutout is available from the editor, the other properties must be added manually to PluginFurnitureCatalog.properties inside the .sh3f file. But then, that is what thread 2006 is all about.
[Dec 13, 2017, 9:51:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you want, you can update the colors by another colors or textures.
Comments are welcoming by PM. wink
[Dec 13, 2017, 5:24:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hexilium
I used it in my project, so thank you.
Too often, reaching for thoughts, we abuse our patience Księgowa Jelenia Góra.
[Jan 15, 2018, 9:20:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
