Previous Thread This topic has been viewed 5157 times and has 2 replies Next Thread
moleto3@gmail.com
South Africa
Version 5.6 Solution (Windows 10)
I had a problem with version 5.6 using Windows 10 64 bit with error message "DirectX/OpenGL". I installed dxwebsetup.exe, JavaSetup8u151.exe and SweetHome3D-5.6-windows.exe. The problem was solved. I am using HP Pro-book 650 G1, I was running Windows 7 32 bit then upgraded to Windows 10 64 bit and the problem started but now it is solved. biggrin biggrin laughing laughing
[Jan 4, 2018, 7:20:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Version 5.6 Solution (Windows 10)
Great! Thanks for your feedback smile
As Sweet Home 3D comes with its own copy of Java, I wonder if installing JavaSetup8u151.exe is really required. And what is dxwebsetup.exe?
[Jan 5, 2018, 8:49:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
moleto3@gmail.com
South Africa
dxwebsetup.exe it is a DirectX Web Setup file, it checks if your system is up to date with DirectX.
[Jan 5, 2018, 9:33:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
