adryan_g78
Romania
Re: Draw tiles in bathroom
Right click inside the room and select modify rooms. Then change the wall base to a tile texture that you like. If you want all the wall to be covered with tiles, select that option from the same window.For bases you can specify the height, meaning that a 7 cm height lets you create a plinth and a 150cm height will cover your wall with texture at that height.
[Jan 23, 2018, 7:15:48 AM]
[Link]
