Total posts in this thread: 2
Previous Thread This topic has been viewed 18939 times and has 1 reply Next Thread
enkonyito
SweetHome3D build failed
When I try to rebuild SweetHome3D, I get the following message:
path\to\Eclipse Java workspace\SweetHome3D>ant
Buildfile: path\to\Eclipse Java workspace\SweetHome3D\build.xml
build:
[javac] path\to\Eclipse Java workspace\SweetHome3D\build.xml:45: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 2 source files to path\to\Eclipse Java workspace\SweetHome3D\build\classes
[javac] warning: [options] bootstrap class path not set in conjunction with -source 1.3
[javac] error: Source option 1.3 is no longer supported. Use 1.6 or later.
[javac] error: Target option 1.1 is no longer supported. Use 1.6 or later.
BUILD FAILED
Configuration:
Windows 10 64-bit
JDK-9.0.1
EnkoNyito
[Jan 24, 2018, 5:47:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: SweetHome3D build failed
You'll have to compile with JDK 8, because JDK 9 removed support for -source and -target javac options with a value less than 1.6.
[Jan 24, 2018, 7:25:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
