Previous Thread This topic has been viewed 2960 times and has 9 replies Next Thread
zerogravity90
confused 3D rendering question
Hi bros,
I load a 5 piece door like in image from obj file. I want to render in 3D that can keep piece fixed size is 70mm for left, top, right and bottom piece.
Thank you so much for any help or any diea.
[Jan 29, 2018, 9:25:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D rendering question
Not easy to understand you.
Can you send us a drawing (started and finished) ?
[Jan 30, 2018, 6:37:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zerogravity90
Thank you so much for your answer,
It mean I load object from obj file. The object contain 5 piece door as in image. When i change ojbect size (width, height or depth), I want control 3D render which can keep 4 piece on door fixed size, just change the center piece of door.
Sorry for my bad English. Waiting for your answer.
Thanks!
[Jan 30, 2018, 4:42:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If I understand correctly, you probably want to edit the .obj with another software. The only way I know to do this with SH3D is if the centre piece has a different colour in the SH3D file (that is a different material in the .mtl file. Then you can set first the centre piece to invisible and export the rest. Then set the rest to invisible, make the door visible, and export. Then you have two different element you can import individually, scale and fit together with SH3D.
But, editing the .obj file with other software is probably easier.
[Jan 30, 2018, 5:23:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Another easy idea is to put these 5 objects in a group. wink
After you can update the group or one or more easily.
[Jan 31, 2018, 6:06:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zerogravity90
Sorry for wrong meaning about question. I loaded obj file, in the applet, when i resize cabinet has 5 piece door above, but when i resized it, cabinet scale all piece by ratio. So 4 piece of out side scaled,too. I already fixed size for them. But it's take effect for every cabinet on same original model. I try modify ModelManager.java and HomePieceOfFurniture3D but not lucky.
[Feb 1, 2018, 4:43:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Every part of a 3D model is proportionally enlarged or reduced when you resize it.
If you want that the frame of the door keeps the same width for a larger door, you'll have to use other software like Blender.
[Feb 2, 2018, 12:06:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zerogravity90
Hi Emmanuel Puybaret,
That's what i need. I'm using Blender to create object, but how can i do to keep the frame of the door keeps the same width for a larger door on Blender? You mean I need to create other model for the same cabinet?
Thank you so much!
[Feb 3, 2018, 1:45:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Blender is not easy to learn but once mastered, it’s a great tool to update vertices in a 3D model, moreover because it preserves pretty well OBJ files at import/export.
If you want a larger cabinet you’all have to modify its 3D model and save it as an other OBJ file. Good luck!
[Feb 3, 2018, 4:40:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zerogravity90
smile Re: 3D rendering question
Finally, I solved it by modify Piece of Cabinet on UpdatePieceOfFurnitureModelNode funcion. But it's a bit slower
Any idea or improve that code.
* Updates transform group children with <code>modelMode</code>.
public void updatePieceOfFurnitureModelNode(Node modelNode, TransformGroup normalization, boolean ignoreDrawingMode,
boolean waitTextureLoadingEnd) {
HomePieceOfFurniture piece = (HomePieceOfFurniture)getUserData();
try {
float originalWidth = piece.getFloatValueFromMiscDataString("OriginalWidth"); //Get original define width
float scaleRatioW = (float)(originalWidth / piece.getWidth()); //Get current width
float originalHeight = piece.getFloatValueFromMiscDataString("OriginalHeight");
//Get original define height
float scaleRatioH = (float)(originalHeight / piece.getHeight());//Get current height
if (!piece.getReloaded())//If Piece need reload
for (int k = 0; k < ((Group)modelNode).numChildren(); k++) {
Node t = ((Group)modelNode).getChild(k).cloneNode(false);
if (scaleRatioW != 1 || scaleRatioH != 1) {
if (scaleRatioW != 1.0 && !t.getUserData().toString().contains("angle")) {
if (t.getUserData().toString().contains("Shaker_fl")) { //Left piece
Shape3D shape = (Shape3D)t.cloneNode(false);
for (int c = 0, n = shape.numGeometries(); c < n; c++) {
Geometry geometry = shape.getGeometry(c);
if (geometry instanceof GeometryArray) {
GeometryArray geometryArray = (GeometryArray)geometry;
int vertexCount = geometryArray.getVertexCount();
if ((geometryArray.getVertexFormat() & GeometryArray.BY_REFERENCE) != 0) {
if ((geometryArray.getVertexFormat() & GeometryArray.INTERLEAVED) != 0) {
float [] vertexData = geometryArray.getInterleavedVertices();
int vertexSize = vertexData.length / vertexCount;
float leftMostValue = 1000;
float rightMostValue = -1000;
for (int index = 0, j = vertexSize - 3; index < vertexCount; j += vertexSize, index++) {
if (vertexData [j] < leftMostValue) {
leftMostValue = vertexData [j];
if (vertexData [j] > rightMostValue) {
rightMostValue = vertexData [j];
if (vertexData [j] == rightMostValue) {
vertexData [j] = (float)(leftMostValue + 0.7 * scaleRatioW);
geometryArray.setInterleavedVertices(vertexData);
shape.setCapability(ALLOW_AUTO_COMPUTE_BOUNDS_WRITE);
shape.setCapability(ALLOW_BOUNDS_WRITE);
shape.setCapability(ALLOW_CHILDREN_WRITE);
shape.setGeometry(geometryArray, c);
} else if (t.getUserData().toString().contains("Shaker_fr")) { //Right piece
if (vertexData [j] == leftMostValue) {
vertexData [j] = (float)(rightMostValue - 0.7 * scaleRatioW);
// System.out.println("fr1");
} else if (scaleRatioH != 1.0) {
if (t.getUserData().toString().contains("Shaker_fb")) {
// System.out.println("ft");
float topMostValue = 1000;
float bottomMostValue = -1000;
if (vertexData [j + 1] < topMostValue) {
topMostValue = vertexData [j + 1];
if (vertexData [j + 1] > bottomMostValue) {
bottomMostValue = vertexData [j + 1];
if (vertexData [j + 1] == bottomMostValue) {
if (t.getUserData().toString().contains("Drawer_Small")) {
vertexData [j + 1] = (float)(topMostValue + 0.37 * scaleRatioH);
} else {
vertexData [j + 1] = (float)(topMostValue + 0.7 * scaleRatioH);
// System.out.println("ft1");
} else if (t.getUserData().toString().contains("Shaker_ft")) {
if (vertexData [j + 1] == topMostValue) {
vertexData [j + 1] = (float)(bottomMostValue - 0.37 * scaleRatioH);
} else {
vertexData [j + 1] = (float)(bottomMostValue - 0.7 * scaleRatioH);
normalization.addChild(modelNode);
setModelCapabilities(normalization);
// Add model node to branch group
BranchGroup modelBranch = new BranchGroup();
modelBranch.setCapability(BranchGroup.ALLOW_CHILDREN_READ);
modelBranch.setCapability(BranchGroup.ALLOW_CHILDREN_WRITE);
modelBranch.setCapability(BranchGroup.ALLOW_CHILDREN_EXTEND);
modelBranch.setCapability(BranchGroup.ALLOW_DETACH);
modelBranch.addChild(normalization);
if (!ignoreDrawingMode) {
// Add outline model node
modelBranch.addChild(createOutlineModelNode(normalization));
// TransformGroup transformGroup = (TransformGroup)modelNode;
TransformGroup transformGroup = (TransformGroup)getChild(0);
// Remove previous nodes
transformGroup.removeAllChildren();
// Add model branch to live scene
transformGroup.addChild(modelBranch);
if (piece instanceof HomeLight) {
BranchGroup lightBranch = new BranchGroup();
lightBranch.setCapability(ALLOW_CHILDREN_READ);
HomeLight light = (HomeLight)piece;
for (int i = light.getLightSources().length; i > 0; i--) {
PointLight pointLight = new PointLight(new Color3f(), new Point3f(), new Point3f(0.25f, 0, 0.0000025f));
pointLight.setCapability(PointLight.ALLOW_POSITION_WRITE);
pointLight.setCapability(PointLight.ALLOW_COLOR_WRITE);
pointLight.setCapability(PointLight.ALLOW_STATE_WRITE);
BoundingLeaf bounds = (BoundingLeaf)getChild(1);
pointLight.setInfluencingBoundingLeaf(bounds);
lightBranch.addChild(pointLight);
addChild(lightBranch);
// Flip normals if back faces of model are shown
if (piece.isBackFaceShown()) {
setBackFaceNormalFlip(getFilledModelNode(), true);
} catch (Exception ex) {
// Update piece color, visibility and model mirror in dispatch thread as
// these attributes may be changed in that thread
updatePieceOfFurnitureModelMirrored();
updatePieceOfFurnitureColorAndTexture(waitTextureLoadingEnd);
updateLight();
updatePieceOfFurnitureVisibility();
// Manage light sources visibility
if (this.home != null && getUserData() instanceof Light) {
this.home.addSelectionListener(new LightSelectionListener(this));
p/s : Shaker_fl : is fix left, same with ft, fr, fb.
Thanks for all of your comment!
[Mar 5, 2018, 6:54:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
