Total posts in this thread: 2
Previous Thread This topic has been viewed 2919 times and has 1 reply Next Thread
VE6CPU
Half walls and bulkheads
Hello. I'm designing a room and I have a half wall that I can't figure out how to draw it. Is there a way to make a wall that is only a certain height not from floor to ceiling? Also is there a way to make it say drop down from the ceiling two feet? I need to make a bulkhead in my basement that holds all of the forced air trunks and some electrical and plumbing.
Thanks.
[Jan 30, 2018, 5:43:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GAthena
Re: Half walls and bulkheads
Create the wall with your desired height. Export the wall as .obj next import it to your furniture library. Once you click and drag the wall on to the floor plan,you can change the elevation.
[Mar 25, 2018, 11:17:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
