Texture is lost when importing a simple .dae COLLADA object from SketchUp
I created a very simple box shaped object in SketchUp and mapped a photo as texture to two sides. I colored the other sides. Then, I export the object using File->Export->3D Model as a .dae file. The option to include texture maps is checked.
When I now use the latest SH3D to import furniture, the object is loaded with the right dimensions, but without any texture.
Looking at the .dae file, I must admit that I don't see any reference to the texture in the XML content (without really understanding the file format).
Re: Texture is lost when importing a simple .dae COLLADA object from SketchUp
Most likely reason: When Sketchup saves a textured .dae file, it creates a subdirectory with the same name as the .dae file with the textures. The .dae file has relative links to the textures, so if the directory is no longer available--e.g. if the .dae file was moved--SH3D will not find the textures when the .dae file is imported. A texture link in a .dae file looks something like this.
