Russia
Export walls to CSV/XML
Hello!
I need to calculate cost of drown house (timber wood), it would be very usefull to export walls somehow (Height 1, Height 2, Width, Tickness) in order I calculate amount of timber and accompanying materials in Excel. May be it is possible, I just don't know how to do it?
Now I use "Calculate walls area" feature and multiply it to wall tickness, but it would be much more preciously if I can use list of walls.
Re: Export walls to CSV/XML
Not directly, as far as I know. But as you mention xml (as opposed to xls)...
You can extract the Home.xml from the (compressed) .sh3d file. There you will find a list of walls with dimensions. With some text editing you should be able to import the values to a spreadsheet for further calculation.
