Total posts in this thread: 9
Previous Thread This topic has been viewed 1969 times and has 8 replies Next Thread
morellik
italy
create sh3f library
I have a lot of objects to load in Sweet Home and I don't want to do it "one by one". Is there a program I can use to create a library sh3f ? Thank you.
[Feb 25, 2018, 7:27:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: create sh3f library
Try the Furniture Library Editor.
[Feb 25, 2018, 8:05:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
morellik
italy
All OK, thank you.
[Feb 28, 2018, 5:29:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lesni
To use this Editor, must I install Java?
My employer has restrictions on unauthorized programs.
Is there a way to have this as a plugin rather than stand-alone.
[Oct 21, 2018, 9:01:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You must have Java somewhere, installed with an installer or copied from elsewhere.
The Furniture Library Editor doesn't exist as a plug-in.
[Oct 21, 2018, 10:06:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lesni
Thanks,
I found the javaw in the bin folder.
Using the command I can start it.
[Oct 22, 2018, 2:17:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lesni
In Sweet Home 3D I put an ini file to make the rows and columns readable. Is there one for this program also?
[Oct 22, 2018, 2:31:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you have a HiDPI screen, install Java 10 or 11. That will fix the issue.
Note that the ini file used for this purpose with Sweet Home 3D isn’t necessary with version 6.0, and I’ll be happy to know how it works for you.
[Oct 22, 2018, 8:31:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
If You've already import the furniture piece-by-piece (name are shown in italic), You could save all in a personal furniture library which could be loaded when needed.
1. Install the ExportToSH3F-1.0.sh3p plugin;
2. In menu: Furniture > Export imported furniture to SH3F...
Note: Sometime You need to make fine adjustment in PluginFurnitureCatalog.properties file.
[Oct 22, 2018, 6:01:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
