italy
tiled texture
I'd like to add a painting to a wall using as texture a jpeg picture of monalisa. I can import the texture but I get a tiled result. Is there a workaround or I must create a 3d object outside SH ? Thanks.
Re: tiled texture
You can use this frame , for example, and change the canvas texture with imported Mona Lisa which will apply without tiled aspect. Only mind the proportion.
