Total posts in this thread: 2
Previous Thread This topic has been viewed 2393 times and has 1 reply Next Thread
peterweaver
How to set up sunshine thru window and shadow inside of a building?
Hi there,
Is it any possibility to set up a sunshine angle and direction through window into a building etc?
Cheers
[Mar 8, 2018, 6:33:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to set up sunshine thru window and shadow inside of a building?
..sunshine angle and direction through window into a building...
The rendering relies on the settings in the compass to provide correct sunlight direction. If you set orientation, lat/long and time/date you can get all possible sunlight angles. Look for enkonyito's and Ceciliabr's forum posts on Photo-video rendering if you need to adjust further light parameters. But yes, you can get pretty much any illumination you wish. okk
[Mar 8, 2018, 8:17:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
