Previous Thread This topic has been viewed 406 times and has 2 replies Next Thread
PacWood
setSelectedLevel gives an Error
Hello,
I am attempting to select a level in a building via the API.
Below is a snippet of code that successfully runs until
the last line is reached.
var HOME;
var HPC = viewHome("viewerCanvas",
homeUrl,
onerror,
onprogression,
{ roundsPerMinute: 0,
navigationPanel: "default",
levelsAndCamerasListId: "levelsAndCameras",
selectableLevels: ["Level 1", "Level 2"],
activateCameraSwitchKey: true
HOME = HPC.getHome();
var theLevels = HOME.getLevels();
var levelName = theLevels[0].getName();
console.log('levelName: '+levelName);
var objLevel = theLevels[0];
console.log(objLevel);
HOME.setSelectedLevel("Level 1", objLevel);
At the line:
A javascript error occurs, which is:
"Error: TypeError: m.getElevation is not a function"
However, the code prints the object 'objLevel'
I can see in the console log, the object 'objLevel' shows
there is a function named "getElevation".
Does anyone have an idea why there is an error of
"getElevation is not a function"
and yet there is a function named "getElevation" in the object
that is being passed to HOME.setSelectedLevel() ?
Below is a screen shot of the console output.
thank you for your help.
[Apr 11, 2018, 7:42:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: setSelectedLevel gives an Error
Sorry, the JSDoc of setSelectedLevel isn't clear and will be fixed in the next version.
setSelectedLevel takes only one parameter:
HOME.setSelectedLevel(objLevel);
[Apr 11, 2018, 11:07:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PacWood
Thank you very much for your help and example code.
The program works now.
[Apr 11, 2018, 4:38:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
