Total posts in this thread: 6
Previous Thread This topic has been viewed 1016 times and has 5 replies Next Thread
confused Opaque window
how to make an opaque glass ?
wink
[Apr 26, 2018, 6:17:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Opaque window
By "opaque", do you mean the glass should let some light go through, but without being able to distinguish objects being the glass? Not sure it's really possible in Sweet Home 3D, but you can try with some glass textures on some transparent material, like in this video at 3'05".
[Apr 26, 2018, 2:23:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Opaque window
Yes, exactly !
Not sure it's really possible in Sweet Home 3D, but you can try with some glass...
I did many tries without success. sad
An idea : I read this morning a fetaure of enko on light about a vertical surface... wink
but how make this object ?
[Apr 26, 2018, 4:42:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Golia
Re: Opaque window
Hello, if I understand correctly you want to adjust the transparency of an object
I'm going to change the mtl property of the obj file
is this what you're interested in?
translated google
[Apr 26, 2018, 8:46:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Golia
Re: Opaque window
newmtl Glass
illum 1
Ka 0.0 0.0 0.0
Kd 0.5019608 0.49803922 0.49803922
Ks 0.0 0.0 0.0
Ns 1.0
Ni 1.0
d 0.9 <---- opaque
newmtl Glass
illum 1
Ka 0.0 0.0 0.0
Ks 0.0 0.0 0.0
Ns 1.0
Ni 1.0
d 0.2 <---- transparent
[Apr 26, 2018, 8:50:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Opaque window
translated google
Hi Golia,
It was a good idea but no ! crying
I explain :
I did that you said with the mtl file (d 0.975 ).
Directly under sh3d, Yes with a outside screenshot ! applause
Look at the left side...
But in standard rendering...
Outside and without light, opaque propertie has disappeared.
Outside and With light, no difference.
Inside without light, no difference !
Inside with light, same result !
Thank you for your idea but it's not positive... wink
[Apr 27, 2018, 7:37:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
