Romania
Remastered furniture
1. On official Furniture and in Contributions properties files I've add: doorOrWindowWallThickness#nn=xx.x doorOrWindowWidthDepthDeformable#nn=false for all doors and windows which have specify the doorOrWindowCutOutShape#nn=xxxx parameters for some of them I need to add also the doorOrWindowWallDistance#nn=xx.x I verify all to look correctly on 7.6 and 50 cm wall thiknes.
2. On Furniture.jar: - add new category: Decorations; Geometry; Light sources; Roof - rename category "Staircase" to "Staircases & railing" - verify all obj file and add mtl files in contributors
3. On Contributions.sh3f: - verify all obj file and add mtl files where neded; some of them I regenerated by SH3D - create separate folders for all furniture (170 from 469); modify properties accordingly - prevent from loading some furniture (ignored#nn=true): -- which are already in official Furniture (25) -- those which are identical as object but only with different colors (9) Note 1: who whant to restore some of them is souficient to comment the "ignored" line. Note 2: to prevent overwriting the original I save this with Contributions-M.zip ("M" from modify) Note 3: I don't modify the translation in specific files;
Who want to test them could be downloaded from here: Furniture ; Contribution-M If something went wrong or suggestions please indicate the furniture name and id number.
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
