Total posts in this thread: 7
Previous Thread This topic has been viewed 1478 times and has 6 replies Next Thread
ZioLollo
Render problem with light and reflections
All objects have been set to opaque, here below render without and with lights:
Render without lights
Render with sunlight
I want the black elements to remain black
[May 16, 2018, 10:43:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ZioLollo
Re: Render problem with light and reflections
I tried to make every 3d model material opaque, but the reflected effect remains.
I need help :/
[May 17, 2018, 11:55:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This gray must come from an ambient color or a reflection color set on these elements. Where did you get them?
[May 18, 2018, 11:44:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ZioLollo
console ps4 is a 3d model that I downloaded, so I rearranged it on Blender. On sh3d all the materials of the model I have set on an opaque color, then I tried to replace all the colors with the texture, but the result is this
[May 19, 2018, 8:51:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Your model could be too shiny. Select the objects, choose Furniture > Modify menu item and click on Matt radio button in modification pane to check if it works better.
[May 20, 2018, 5:52:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ZioLollo
I downloaded 3d object from https://3dwarehouse.sketchup.com/ in collada file. When I import them in sh3d I always have problems of reflection of light, as if the objects were shiny even if I imposed them all on opaque
[Jul 25, 2018, 10:57:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
I had the same problem several times. You have to figure out which of the materials of the model it is and set it to "invisible".
Pascal
[Jul 25, 2018, 11:47:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
