United States
Photo not working properly
(I know there's already several "The photo thing doesn't work!" threads out there, but I'm having a different problem than most of you guys seem to be having.)
OK, so I'm trying to get a photo of this room:
But when I take a photo, I get this (pardon the size, it's supposed to be for a particular purpose):
It's too close up and too dark. Is anyone else having this problem? How do I fix it?
strong bad...Cute....
Re: Photo not working properly
There seems to be a problem to view the images you wanted to share Anyway, hope you'll find this tip useful.
As it’s not completely dark, I would think it’s more a lighting problem. You should select the Add ceiling lights option or add source lights for better control. See also this tip.
United States
Alright, thanks! Moving the virtual visitor definitely helped - turns out that in my attempt to get a good POV, I ended up with him inside the wall. Problem solved! Here's the finished product:
