Previous Thread This topic has been viewed 1915 times and has 9 replies Next Thread
confused Light properties
who knows the name of the property to fix the brightness of a light source in the properties file named 'pluginFurnitureCatalog.properties' ?
confused
[Jun 2, 2018, 12:18:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Light properties
The property is lightSourceColor#..., fully black matching no light, and white #FFFFFF matching a white light at full power.
See DefaultFurnitureCatalog.properties for examples.
[Jun 3, 2018, 12:40:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank your for your return.
My ask has been not understand perhaps by using bad words, I wanted to say the power of lightsource (0 to 100%) and not the color. biggrin
I want to change the default value (50%) to 5% (for example).
but… I didn't see this in given file.
[Jun 3, 2018, 8:19:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You can find all the properties in DefaultFurnitureCatalog.PropertyKey.html.
You will, as indicated by Puybaret, need to adjust RGB down in sync. The power is, however, saved in Home.xml, as that reflects the adjustment made by the user in the design.
[Jun 3, 2018, 7:11:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great !
Do you know how to update this data in a sh3f file ?
biggrin
[Jun 4, 2018, 6:19:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Use a zip utility to extract the PluginFurnitureCatalog.properties file from a SH3F file and rezip it at the end, and a text editor to edit the PluginFurnitureCatalog.properties file.
[Jun 4, 2018, 11:36:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry if I was unclear. There is no power setting in .sh3f/PluginFurnitureCatalog.properties (only in .sh3d/Home.xml). In .sh3f/PluginFurnitureCatalog.properties you can use the html (six digit hex) colour notation:
a very bright white light would be:
lightSourceColor#xxx=#FFFFFF
a 'normal sh3d white' lightsource is (if I remember):
lightSourceColor#xxx=#BBBBBB
a much less bright 'white' light would be:
lightSourceColor#xxx=#222222
[Jun 4, 2018, 11:51:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TY okh.
Damned, a parameter only manually update. crying
Perhaps a adding to do in whislist section for next 5.8… wink
[Jun 4, 2018, 12:51:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@bdfd
This is possible in a derived version of SH3D by modifying line 53 of the HomeLight.java file.
EnkoNyito
[Jun 5, 2018, 12:03:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@bdfd
TY enkonyito.
But I don't like this because it's "all or nothing"... biggrin
I explain : I want to update ONE object in a sh3f not all objects of same type in SH3D.
wink
[Edit 1 times, last edit by Puybaret at Jun 6, 2018, 11:31:07 AM]
[Jun 5, 2018, 6:15:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
