Total posts in this thread: 7
Previous Thread This topic has been viewed 4897 times and has 6 replies Next Thread
uniqueAndreas
Germany
Sweet Home does not start on my new Mac
After changing to a new Mac (MacOS 10.13.5) I wanted to install Sweet Home 3D again on this machine. But for some reason it does not start anymore. I tried version 5.7.
I have Java 8.1 installed. However Sweet Home does not start without any error message.
Can you help, please? sad
Best,
Andreas smile
[Jun 6, 2018, 3:21:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sweet Home does not start on my new Mac
The DMG installer version requires Apple Java 6.
If you want to run Sweet Home 3D with Java 8, you'll have to use the Java Web Start version or the JAR executable version.
[Jun 6, 2018, 9:13:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
uniqueAndreas
Germany
Hi Emmanuel,
Thanks very much! This solved my problem.
Best,
Andreas
[Jun 10, 2018, 12:10:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
tahitipr
I'm on macOS 10.13.5. Java 10.0.1 installed. Online version not running even when allowed in safari's plugins preferences. Java Web Start version or the JAR executable version are not working either. Any advice?
Thanks!
[Jun 30, 2018, 2:54:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Install Java 8 rather than Java 10.
[Jun 30, 2018, 9:53:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lukaskupasz
Polska
I have macbook pro with IOS 10.7.5 version and I used Sweet Home 3D application on a project this spring. Everything worked fine until today when I uploaded Sweet Home 3D update (version 5.4.2). Suddenty the app won't open at all.
I downloaded the latest Java 8, restacted mac, uninstalled and installed again SH3D but nothing helped. I really need this to work because I need to finish a project for a client by end of this week and I am stuck here.
Can you please help?
[Jul 4, 2018, 10:24:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The latest version available on the Mac App Store is 5.7.2 but can only run under Mac OS X 10.8.3 and higher.
Oracle Java 8 isn't supported under Mac OS X 10.7.5. But you can use the free version 5.7 available at Download page which runs with Apple Java 6.
[Jul 6, 2018, 11:05:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
