Rotate a single freestanding wall
Hello, I am designing the interior of a video studio that has various sets. In order to find the best layout I want to create the sets as walls and then move them around inside the room looking for the optimum placement.
I see only two ways to create walls: Use the wall tool, or use boxes. I would prefer to use walls for a variety of reasons, BUT, I don't see a way to rotate, or tilt walls ( or a single wall ). In order to move my sets around, I have to be able to rotate them. Can't see how to do that with walls, unless I am missing something.
Why use walls instead of boxes? Because I can curve walls but not boxes Because walls of lower levels are visible from walls of higher layers (I use higher layers to design lighting grid layout, etc., and life is easier if I can see the lower level.
Re: Rotate a single freestanding wall
Welcome You should try the Edit > Rotate menu item the Advanced editing plug-in.
