Total posts in this thread: 2
Previous Thread This topic has been viewed 1832 times and has 1 reply Next Thread
wingedoak
US
confused 2D Floorplan only, No 3D, Using Windows 10
I am a new user to Sweet Home 3D and loving it! However, unless I print to PDF, or Create a Photo, I never see a 3D version of the home I've created. Nothing under the "3D View" menu besides "create photo" works. I have recently downloaded and installed the latest version of Flash, just in case that was an issue. I'm not sure what else to try. Any suggestions would be appreciated.
[Jun 23, 2018, 2:18:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2D Floorplan only, No 3D, Using Windows 10
Are you sure you just did not pull the 3D window all the way down? If so, there are two small arrows under the ruler in the 2D window. Grab the line with the arrows at the bottom of the 2D window (inside the SH3D window, if not you will just resize the entire SH3D window).
[Jun 24, 2018, 8:55:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
