Sweet Home 3D 6.0
This topic has been viewed 1248037 times and has 196 replies
Thread status: Active
Test the features and bug fixes of future versions [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
User avatar
UbuntuBirdy
Country: Switzerland
Contact:
Re: Sweet Home 3D 6.0
Post by UbuntuBirdy »
@Hans
Does this issue appear with both video card drivers, the one offered by Ubuntu (Open Source) and the one offered by Nvidia (proprietarily)?
I ask this question because I am not able to reproduce this issue on my Ubuntu 18.04.
Pascal
User avatar
Country: Netherlands
Post by hansmex »
I tested this with the Envidia driver recommended for my video card, and with the X-driver that's native to Ubuntu. Both give the same results.
What do you think?
User avatar
UbuntuBirdy
Contact:
OMG! I'm so sorry! Who can read is in the advantage... I have to stop doing multiple things at the same time...
Pascal
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
The final release of version 6.0 is out. Enjoy! [:)]
The portable version will be released a little later once I'll gather more translations.
Thanks all for your tests, your feedback, your support and... your patience.
User avatar
YGYL
Post by YGYL »
I don't think the translation is right here.
选择唯一可见楼层(Make select level the only viewable one)
It should be changed to
只可见该楼层
User avatar
Post by hansmex »
While making a few renders for another thread, I noticed that after finishing the rendering, SH3D keeps using all 6 cores of my processor at (close to) 100%, just as it does while rendering.
This heavy usage only stopped when I shut down SH3D.
I also noticed that when applying a transparent texture to vertical blinds, the blinds are shown as completely black in the 3D preview window. Is this a regression? We also had this in some earlier version.
(beta 6.11 under Ubuntu 18.04)
EDIT
Meanwhile I installed version 6.
- Processor stops at end of rendering. (same file & settings as before)
- Transparency still shown as black.
User avatar
UbuntuBirdy
Contact:
In SH3D 6.0 the GPU load for the 3D view (only virtual visitor) is reeeeally high, strange high. In fact it's higher than in any other application, even higher than in complex 3D games or benchmark tests. It's much higher than in 5.7 or any older versions.
This is not a big issue, because the max temperature of the polaris chip is approximately 90° C and atm the actual temperature is at 55°, but it's a noisy (because of the fan) one...
Normally the temperature of the GPU is not higher than 40°.
Pascal
User avatar
Country: LILLE, Les Hauts de France, Western Europa
Post by bdfd »
I'm agree with hans and Ubuntu about 3D renderings. [;)]
With the final 6.0, I find that a 3D rendering is too important for the main processor and not for the GPU. [:D]
Here are the results on my PC :
Tested with Core i7-4790 - RAM 16Go - GC : GeForce 970 GTX 4 Go
CG is 4 years old, is this the weakest link ??? [:D]
@Puybaret : what can you do to ameliorate this point ?
User avatar
YGYL
Post by YGYL »
WINDOWS version does not have this problem.
User avatar
UbuntuBirdy
Contact:
The problem on my system does not occur while rendering, only in the 3D view in virtual visitors mode while "walking around".
Pascal
Post Reply New Topic
Who is online
