Italy
Wall capy and paste
Hi all. Is possible to make a copy and paste of walls already built in another project? I need them with a certain angle, that’s the problem. Is that possible? I don’t want to import as an obj because then i cannot edit anymore. Thanks again!
Re: Wall capy and paste
You can select the walls you want to copy, choose Edit > Copy menu item, open the other project, click in its plan and choose Edit > Paste menu item.
I just tried and you can rotate walls with the plugin. Please try again.
