Re: Azure Home
I like very much the idea for the office! Also the other one.
TY.
Should I leave the door for the office near the stairs, once entering the house, or should I remove it and leave only the access through the living room? Imho I should leave the door :).
For practicity, let the door if not you should do all the round to go to the entry.
In the same style, you can put a sliding glassed door between office and living room like this :
Re: Azure Home
Love the colors used on this project, would be nice set overlooking a beach. One thing i noticed on the plan, i am not sure about the regulations in Italy, but in the UK you cannot have the top of the stairs that close to a door. Mike
Re: Azure Home
No problem for this in France ! .
Italy
Re: Azure Home
Thank you Mike, sooner I will try to put a beach overlooking. I do not know the regulations here in Italy, but for now the house is only a virtual project, if someone will decide to build you I will get some info about it :).
Unfortunately now I am preparing some exams so I have not time to dedicate to this project but I after this session I will start working on the interiors :).
Italy
Re: Azure Home
Beautiful renderings! You are creating very nice moods. ___
You could try scaling down the height of your sky images so you get the clouds closer to the horizon – and see what happens :)
Here the sun is behind the house so everything is in shadow, but the idea was exactly that, simulate the morning sun.
And to make the snapshot absolutely perfect, you should turn the compass a bit, so that the shadows of the sun matches the sky image.
Thank you for the suggestions Cec, I need to take confidence with the sh3d way of managing the background image.
For now, I tried to use the advanced rendering plugin (I was able to make it work). The image I posted some time ago was this one:
Using the plugin I realized this one:
I think the colors and shadows are better, and the overall quality of the rendering is better, it is not perfect because I do not play as required in order to find the best lights. I am only at the beginning with this plugin but I think there are great possibilities to realize great renderings. I will be happy if I could realize closed to reality renderings as those seen by you or other sh3d users that posted into Gallery.
Re: Azure Home
..you should turn the compass a bit...
@cec As an amateur navigator, I object! I have met women who wanted the Earth to move, but a compass is not the best way. You should adjust the date/time - and if it still does not fit, you need to shift the background image...
@AdeleAlli: Great renerings. Love the feel you created. Speaking of the compass, where is this?
Italy
Re: Azure Home
ok (Just back from Sardinia...)
It is hard to find the exact and perfect position of everything in order to create realistic atmospheres, but I will try (maybe after September 14th, because I should study for an exam XD).
I love this software and I want to be able to create perfect or almost perfect renderings so usually I fail in studying and then I play with sh3d XD.
Thank you okh. Somewhere in south Italy, maybe near Catanzaro (Calabria), I saw many villas that I appreciated and this is inspired by one of those.
