India
RULES FOR DEFINING 3D STRUCTURE
Hi all ,
Thanks for making sweet home 3D , i have a query as in can the code be modified enough to create rules for particular structure eg , can the rules for bedroom size , bathroom size and kitchen size be made if the total area is input by the user ?
India
Re: RULES FOR DEFINING 3D STRUCTURE
Standard rules like bedroom area will be thrice of the kitchen area or bathroom area is 1/2 of the kitchen area .certain rules for standard area accoring to the BHK eg 1 BHK , 2BHK
As with any program, you can program all the controls you want. But the good question is when and how should be displayed the controls you want to add. If you display a popup as soon as your conditions are not verified, this may interrupt user's input. If you want to add a menu item that will check your conditions, you might not be able to force the user to modify his design. Maybe you could try to program a plug-in for this?
