Previous Thread This topic has been viewed 3375 times and has 2 replies Next Thread
carltonwb
United States
Where to install .eteks
Using Mint 19
I installed Sweethome3d in the /opt directory.
Where do I install the .eteks folder in order to use the plugins.
Also if I installed this through the software channel it creates a snap file, where would I install the .eteks folder in that case.
Thanks
carltonb
[Sep 4, 2018, 11:04:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Where to install .eteks
Run once Sweet Home 3D and modify something in its preferences to let the software create the .eteks/sweethome3d folder in your home directory. Then you can create a subfolder named plugins in .eteks/sweethome3d.
[Sep 6, 2018, 9:30:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
carltonwb
United States
Thanks worked exactly as you stated.
[Sep 6, 2018, 7:35:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
