Features
Posts: 16   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 1130 times and has 15 replies Next Thread
YGYL
applause Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)
Pre-segmented dynamic object system is like this GIF picture.
gif file
[Sep 26, 2018 8:21:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
YGYL
biggrin Water pipes and electric wires
Download the file
Water_pipes_and_electric_wires.sh3d
2D
vertical 2D view
3D view
3D detail
[Sep 27, 2018 4:29:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Water pipes and electric wires
Good idea !
In France, all electric network is in the ceiling.
It's easier to access and it avoids flooding … wink
only 6.0 and nothing else - W10 64b
[Sep 27, 2018 7:41:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Woods and grass
Woods and grass
Download the file
Woods_and_grass.sh3d
2762 grass objects with different directions and sizes
2D top view
3D view
Trees with different directions
Rendered graph
[Sep 27, 2018 12:17:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Re: Woods and grass
If you don’t have a random distribution system, it takes a lot of time to do this kind of map.
If you can randomly distribute the specified multiple objects, including
Random location within range
Random size within range
Random direction or both directions
Range random machine height
Well, doing this is very fast.
[Sep 27, 2018 12:30:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Re: Woods and grass
My thoughts on Pre-segmented dynamic object system's custom user interface
Allow advanced user defined material library
It also provides ordinary users to define him in software.
This will be a great pleasure for software. I hope users can create some interesting things when using software. So there is no need for too many restrictions.
The whole process is reflected in a Script form. The software executes some items on the table down.
If set correctly, those cases in my front post will be reached.
After execution, a new object is generated in the object bar. Drag and modify this new object to automatically create complex objects.
Script form
Type is the most important column.Determines the function of this script.Other columns are his parameters.
left
Middle (simple)
Pattern 1
Pattern 2
Pattern 3
Right
corner
Inner corner
Outer corner
Random placement (square)
Random layout (circle)
Several choices 1 (Book)
Intermittent repetition
blank
[Oct 13, 2018 12:14:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
