Re: cylinder mod?
Mike,
The cylinder from the library is defined in three parts. If you make top and bottom invisible, you are left with a ring. Note that the wall thickness will be zero.
Re: cylinder mod?
Thx for the reply Hans, not quite what i wanted, :- cylinder 40mm diameter 1.2m long, then give it an arc 180 degrees (like a wall) and put 2 together - Ring. Could not figure anything out with sh3d so i used sketchup. It was to be used as a round edge on a worktop, the island in my last kitchen thx again m8 Mike
